VOLTAGE DIVIDER TOOL
Voltage Divider Calculator
Results:
Additional Parameters:
Tolerance Analysis:
% %✅ Standard Voltage Divider Formula
When two resistors and are connected in series across a voltage source , the voltage across (called ) is:
📘 Explanation:
: Input voltage applied across both resistors.
: Resistor connected to the input side.
: Resistor connected to ground (or output side).
: Voltage measured across — this is the divided voltage.
🔄 Rearranged Forms (if you're solving for other variables):
To find :
To find :
To find :
